Vote for the next Public Tulip API
Hey everyone! My name is Josh and an employee at Tulip. I’m a long-time listener, first-time poster. I want to know which of the following potential new APIs you as a user would find the most valuable. You can select up to three and if you don’t see the one you have in mind listed below then please post it in the comments!
Thanks and happy building!
  • Analytics API: an API to create, edit, and export Analytics
  • Apps API: an API to configure Apps at scale, as well as perform CRUD operations on Apps
  • Automations API: an API to configure and trigger Automations remotely
  • Completions API: an API to read, update, and delete App Completions
  • Library API: an API to create, edit, and delete Libraries across Instances and Workspaces
  • Site Configuration API: a set of APIs to configure settings for an Instance of Tulip
  • Users API: an API to configure Users on an instance of Tulip
  • Other API: Post about it in the comments!
0 voters
Other API: an API to configure machines and machine attributes to reduce implementation time and provides a mechanism to ensure automation system configurations are staying in sync with Tulip machines
100% :raised_hands: Highly support this one too!
I agree with Jesse, this could be a real game changer for scaling
Oh yes! Machines Types, Machines, Machines mapping and attributes.
An API to set downtime reasons for machines ?
An API to read, edit Machine Activity - to be able Status and Downtime reasons in the past.
Hello all! I have been reaching out to people that requested the Users API. We first plan on releasing GET and LIST endpoints for Users in the next 1-2 months.
Are there other capabilities that you are excited about? Let me know here and I am happy to discuss further.
Hi all! As part of the launch for Ops Calling 2024, we did indeed launch a Users API with GET and LIST endpoints. It comes with r289 and later. See our API docs here: /api/users/v1/users - users
If you enjoy this, or have other endpoints you are looking for, let us know in the comments here!
Will you eventually be able to get the custom fields information for users via API?
We could certainly do it in future! Why do you want to get info out of User Fields? I am wondering if there is another way to do that as well.
@kevin.kononenko These questions are going to keep coming until Tulip decides if User Custom Fields is a real table or not. Until this is decided I would recommend most people just design an architecture with a normal table for User Custom fields and load the current user by name or by badge ID “On App Sign In”.
I would vote for more capacity on the existing APIs rather than new development. Specifically for api/v3/tables/[TABLE_UNIQUE_ID]/records
The limit of 100 is much smaller than other APIs that we use. Increasing that limit would help.
We have found it is impractical to pull larger tables (or externally sync larger tables) using the API. If you want to follow one of the integration guides that pull data using the API - you better be prepared to wait a week (1M to 10M records).
Ex. Microsoft Azure Machine Learning Integration or Snowflake Integration with Fabric - Fetch Tulip Tables to Snowflake
Update multiple rows of data with one API call :slight_smile:
API to query whether the specific Connector is online or not
Actually
  • {instance}/api/connectors/v1/w/1/connectors?archived=false&offset=0&limit=25
would provide the connectors list and
  • {instance}/api/connectors/v1/w/1/connectors/online-status?connectorIds=[list of connector id's]
would provide the online status…
unfortunately I think there is no API token you could create yourself to call them successfully…
So this could actually be a quick win for tulip…
Thank you!
Yes, I actually saw that API used in the page, but I want officially supported API for the user.
Yes, mass update/create records API. We need this! so far, the only solution I can find is related to loops or automations.
