LTS 8.2, Life Science / GxP, Private Hosted, with DEV, QA, and PROD instances
How to evaluate the change and determine what steps to follow next
What changed and how significant is the change? (ex. changing a button color, maybe not a big deal, but changing trigger logic could be)
At present, we are only testing changes to functional elements, and currently don’t have any user stories with specific color, size, format requirements for widgets
We do have some user stories wherein display text is specified for widgets and/or single-/multi-select options
So far, if we are not making the former type of changes without the latter, so we don’t have a process for just making changes to content that is outside of user stories
When we do make the latter changes, we are updating user stories in Jira, associating them with a UAT, promoting the revised app from our DEV instance to our QA instance (basically export/import), executing UAT, approving UAT, and then promoting the app from DEV to our PROD instance
How to communicate app changes to internal teams?
What methods or tools do you use for communication and organization?
Typically email at minimum
If changes to Tulip applications would impact SOPs or WIs in a non-administrative fashion, then there would be Read & Undertand training pushed though our LMS (triggered by our DMS)
We have also offered Instructor Led Training to users when deploying new apps, and plan to do so when making functional changes to existing apps
How often are you communicating changes? Is there a cadence?
We do not currently have a standard release cadence, but I like that idea.
For document revisions, we have had better on-time training completions when we’ve stuck to a standard release schedule (i.e. documents go effective / training due on the 14th and 28th of each month), at least for the documents we own
How do you manage approval process for changes?
What “gates” exist and who needs to be an approver?
Approvals for UAT and SDLC/CSV release documentation are all in Jira and Asset Management (not sure if this is a company thing or a widely used IT documentation tool)
Approvers include the Business Application Owner, Technical Application Owner, and Technical Quality, at minimum
Is training required for app end-users and how is that managed?
