Station / Device set up / registration with QR code
Hi All,
I found a neat work around for registering a device / station using a QR code.
PROBLEM - I was a using a device that was connected to the internet but I was not able to easily send a station link to the device. AND ideally i didn’t want to use my SSO details and 2 factor authentication on each device.
SOLUTION
  • I created the station links like normal
  • Used a Tulip app to translate these links in to a QR code using the bar code widget
  • I used the camera on the device to scan the QR code, the QR code opened a link in the browser and registered the device. :grinning:
Sure others have found this before because it is pretty simple but thought it would be good to document for others.
Hi Eddy,
This is great, thanks for posting!
Do you know if it is possible to get the registration link into an app through a variable/connector? Rather than hard-coding it.
Cheers,
Joe
Hi Joe, I know the stations and device api is something that is in the works. Not sure of the release time line though. Let me see what I can find out
Hey Crew -
The Stations API is actually public now, and this dynamic registration can now be done with a connector function.
We use this technique internally now to create stations on the fly, and we do this with 2 functions:
  1. Create station - Returns a station ID
  2. Register Device - Returns the registration links. These registration links can be fed into the barcode widget to render them as QR codes.
Hi Pete,
That is exactly what I was looking for. Tested it and it works perfectly, thanks so much!
Best,
Joe
